Files split by Canon
COW Forums : Canon Cameras
Mandy Leonardo
on Nov 1, 2016 at 4:55:49 pm
Using a canon xa30 and it splits the files at 4G. When I import into Final Cut Pro and piece them together on the timeline, there is a slight blip in audio. Are there any ways around this?
Francois Pénzes
Re: Files split by Canon
on Nov 21, 2016 at 10:55:35 am
Hi Mandy
The files need to be ''linked''. For this, Canon has a utility that does just that. You will still have separate files but linked together. I'm almost sure it will work for you even if you are not working with an XF series camera. Happy shooting !.
Link for Mac:
http://support-ph.canon-asia.com/contents/PH/EN/0200442702.html
Link for PC:
http://support-sg.canon-asia.com/contents/SG/EN/0200331102.html
Cheers !
PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Mandy Leonardo
on Nov 22, 2016 at 8:04:44 pm
Thank you!
