New to forum!! Have Canon XH A1s with damaged A/V1 port
COW Forums : Canon Cameras
Eric Johnson
on Jan 15, 2015 at 11:35:31 pm
Good day all!!
I just purchased a used Canon XH A1s from a local church. It works with the exception of a damaged A/V1 port. Can these be replaced easily? I don't know much about these cameras.....purchased as a gift for my son who is a budding videographer/ film maker. Any advice would be humbly welcomed.
The port looks like a jack may have been pulled out at an angle (someone probably tripped on a cord...who knows). In any case the yellow plastic ring is broken and the female connector is slightly pulled out and bent. It makes only intermittent connection when plugged.
Thank you again for your time!
Eric
