T4i for low-light action shots
COW Forums : Canon Cameras
Mark Batisah
on May 8, 2014 at 5:56:00 pm
I have the T4i and, recently, have had a need to use it to take some low-light action shots. Is there anything I can do to better its performance?
At present I'm using the kit lens with no flash. I'm under the impression the EF 50mm f/1.8 II Lens might produce better low-light action results; is that true? Also, should I look at an external flash and, if so, what would be appropriate?
Thanks in advance for dealing with this novice question -
