Cleaning a Sensor
COW Forums : Canon Cameras
Ali Quintana
Cleaning a Sensor
on May 8, 2014 at 11:53:57 am
I have to clean my camera sensor. Have no idea how to do that.
I live on a asland with no por to do this for me.
Blowers are not helping in this case as the dirt is stuck, a small spot but is is visible in the filmed footage.
Hoping o some good advice.
Todd Boyle
Re: Cleaning a Sensor
on May 9, 2014 at 8:42:13 pm
If it's inside the lens assembly or on the CMOS, CCD, etc. then you have to send it in for servicing-- and since those areas are supposed to be sealed, it's probably covered by warranty.
I have a slightly worse problem, I'm afraid there's been a slight accumulation of moisture somewhere in my HF-G10 causing a very slight darkening or vignetting in the extreme 4 corners of the image when fully zoomed long. I'm just going to live with it, I guess.
© 2018 All Rights Reserved
