C100 strange results ...
COW Forums : Canon Cameras
Colin Davidson
on Nov 13, 2013 at 11:45:45 am
Hello there,
I switched on my C100 for the first time this morning, hooked it up to my Ninja-2, did the necessary menu adjustments so I can fire the Ninja-2 from the C100 and set about looking at picture quality.
C100 :
24 Mpbs
LCPM
50i
Ninja-2
1080i50
ProRes 422
I’ve shot a few slow(ish) pans and tilts but when the footage is slotted directly into FCP7 (checking that I choose the same settings as the clip), I have noticed that on these movements, the picture seems to be somewhat jittery. On solid lock-off shots, it’s fine (naturally), but the results on movements in FCP7 aren’t exactly satisfactory. I am not whipping it left and right, just a few slow gentle pans. The image on both the C100 and the Ninja-2 screens are perfect ...
Here’s what I mean:
Could this be how FCP sees an interlaced picture? Is there a workaround or does something need changing within the C100?
Thanks for any help you can give.
William Busby
Re: C100 strange results ...
on Nov 21, 2013 at 2:12:04 am
I assume the problem was fixed since the video has been removed. thanks for letting us know ;)
Colin Davidson
on Nov 24, 2013 at 11:09:42 am
William,
No the problem still exists and, yes, I am aware that the only illustration of this has been deleted.
The problem I have is that whichever sequence setting I use in FCP7 or menu setting within the C100, ANY and ALL resulting files that are supposed to be progressive look terrible. This is something I simply can’t understand.
Herewith, 2 separate projects:
C100 settings:
System Freq: 59.94 Hz
24Mbps
LPCM
PF30
1/50 shutter
Ninja-2 settings:
ProRes HQ
1080p29.97 (2:2)
FCP7 sequence settings:
1920 x 1080
Square
None
29.97
Compressor: ProRes HQ
Pans and tilts look ’strobe-like' and the picture isn’t as ‘smooth' as expected. YouTube test gives much the same result.
Same for the following:
C100 settings:
System Freq: 50.00 Hz
24Mbps
LPCM
PF25
1/50 shutter
Ninja-2 settings:
ProRes HQ
1080p25 (2:2)
1920 x 1080
Square
None
25
I would be grateful for any help that anyone could shed on this ...
Kind regards,
Colin
adam mondon
on Oct 30, 2015 at 3:19:50 pm
Hi Colin,
I know this is a long time after you posted this thread, but do you remember solving the issue above?
I have had exactly the same problem and can't find a way past it.
Mine was this spec that you put on there, minus the ninja(as I didn't use one)
Thanks in advance!
