Importing Canon XF300 footage into Final Cut Pro 7 from back up copy.
COW Forums : Canon Cameras
Paul Tully
on Apr 28, 2013 at 12:00:51 am
We can't import/transcode XF300 footage into Final Cut Pro 7.
Does anybody have a step by step for transcoding into Apple ProRes for editing?
We copied the job from 3 flash cards onto our back up drive but log and transfer in FCP7 is not 'seeing' the files.
Any help greatly appreciated.
Mark Weber
Re: Importing Canon XF300 footage into Final Cut Pro 7 from back up copy.
on Apr 30, 2013 at 3:43:52 am
I have not tried importing into FCP7 (use FCPX instead with an XF105) but you might try looking at the following link which seems very helpful:
http://blog.abelcine.com/2012/02/07/how-to-import-c300-footage-in-avid-fcp-...
There is a section for FCP7. The XF300 uses the same format files as the C300.
Hope this helps.
Mark
Prof Edwin Luna
on Dec 13, 2013 at 2:06:46 pm
Thanks for the tip
Paul Tully
on May 2, 2013 at 10:11:37 am
Problem solved! Never change the name of your files as FCP can't read them. I had renamed 'CONTENTS', changed it back and Log and Transfer worked perfectly. Lesson learnt..
Paul
