Canon HV20 into Final Cut Pro7
COW Forums : Canon Cameras
Ed Durbrow
on Jan 21, 2012 at 11:22:43 am
I'm trying to get video from a Canon HV20 into Final Cut Pro7.
I get this message when I open Log and Capture:
Unable to Initialize Capture Device
and after okaying, in the Log and Capture window: No Communication
Easy Setup settings:
Format: HDV
Rate: 29.97 fps
Use: HDV - 1080p30 Basic
I put the Canon in Play mode. It is set to SP for rec mode, audio 16bit, TV type 16:9,comp.out 1080i, DV output HDV/DV.
I've tried two Firewire cables.
I've done this in the past. I usually load from a Sanyo Xacti. I must have changed some settings but I don't know how to set it so it recognizes the Canon.
