Canon XHA1 wont turn on at all
COW Forums : Canon Cameras
tim gannon
on Aug 8, 2011 at 1:20:22 pm
Wondering if the camera XHA1 needs professional fixing?
It won't turn on to at all. All I get a slight blue flash on the HDV sign on the toggle ring when i try to power up.not even playback will work.I've checked both the stand by buttons, I've checked the batteries and any power supply. It seem pretty bad.
Any suggestions?
Tim
Lou Bruno
Re: Canon XHA1 wont turn on at all
on Aug 14, 2011 at 6:08:27 pm
Dead power-supply unit. Common problem.
Lou Bruno
Tracy wu
on Aug 15, 2011 at 4:08:37 am
connect it to your camera to see if there's any signal
No dress rehearsal in our life,every day was a field pickup.
Sean Sutton
on Jan 9, 2013 at 11:53:25 pm
Hi Tim,
I realise this thread is over a year old but I'm experiencing exactly the same problem.
Can I ask if - and how - you got it fixed?
I'm going to take it to the Canon shop next week but before I do I'd just like to check there's nothing simple I'm missing here!
Cheers
Sean James Sutton - an English actor & filmmaker in Italy.
helio souza
on Mar 28, 2013 at 12:01:04 am
[Sean Sutton] "Hi Tim,
Hi Sean! I wonder if you could solve the problem of your XH-A1. I'm having the same problem and I need help.
Seán Sutton
on Mar 28, 2013 at 8:52:41 am
In the end I took it to the Canon shop and they repaired it. It was the CCD which they replaced. It cost about 800 US (600 EUR) but I figured it was worth it (just).
Works fine now.
an English actor and filmmaker in Italy
