Canon ZR100 Problem
COW Forums : Canon Cameras
Ram Peters
Canon ZR100 Problem
on Dec 16, 2010 at 2:21:32 pm
I have a relatively new canon ZR100 video camera. This camera records to mini DV tapes. I've had this camera for about 2 years, and it has been problem free, untily recently. All of a sudden everytime I put a tape in and turn it on, this LOUD beeping comes on it the LCD screen says "REMOVE THE CASSETTE." It will not play, and it will not record. It does this to every tape I put in with NO explaination.
Does anyone know why the camera is doing this? Or how to fix it? Thanks
Ben Lawrence
Re: Canon ZR100 Problem
on Jan 14, 2011 at 10:12:23 pm
There's a good chance that the tape heads (the spools that read and write to the tape) have either become dirty or warn out. You can try purchasing a cleaning cassette- definitely go with a Cannon brand tape, as they have different viscosity. If that doesn't do it you might look at getting the tape heads replaced. They are however, pretty expensive.
