capturing tape shot with canon xh-a1
COW Forums : Canon Cameras
Kenneth Cleeton
on Nov 16, 2010 at 4:31:11 am
Hey all,
I'm shooting with a canon xh-a1 and I don't want to put time on the heads to capture. I have heard that tape decks are a good choice for something that will last a long time. I have 3 questions.
1. I don't know anything about tape decks, can you also stripe with them?
2. Is there any brand or model that works best with what I shoot with?
3. I'm looking at a sony hvr-m25u, as a possible option, would I need to capture any different than I do with a canon product because it's a sony?
Thanks in advance for your help,
K.L.
K.L. Cleeton
Co-Owner/Lead Editor/Event Specialist
2FAST4U Productions
http://www.2fast4uproductions.com
Todd Terry
Re: capturing tape shot with canon xh-a1
on Nov 16, 2010 at 5:51:00 am
If you are shooting HDV with that Canon (not SD) and shooting in either 24f or 30f mode... because of Canon's proprietaray way of shooting progressive footage you are somewhat limited on decks that will work.
For the longest time, there were no decks that would play the footage... you had to use a Canon camera... hence the popularity of the cheap Canon HV20 camcorders. Many people (including us) bought them just to use as decks.
Finally, a couple of decks did come out that will support the Canon footage. The Sony M35 was the first, and I believe it's probably the most popular. I think there are a couple of others now, but I'm not sure what they are or whether the M25-U is one of them. That would be something you'd definitely want to check on and confirm before investing in a deck.
Remember... that's ONLY if you shoot HDV and ONLY if you shoot 24f or 30f. If you shoot HDV at 60i, any HDV deck will work. And if you shoot standard def, most any DV or HDV deck will work no matter if you shoot 24f, 30f, or 60i.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Brian Louis
on Nov 16, 2010 at 5:28:03 pm
[Todd Terry] "but I'm not sure what they are or whether the M25-U is one of them."
The Sony M35U, M25AU, M15AU will playback native progressive scan, like Todd said the HV20/30/40 will also playback, the HV40 will also record the format, they are a cheaper alternative to the Sony Decks.
