SD Card Recovery on T2i - Anyone used software tools successfully?
COW Forums : Canon Cameras
Alf Hanna
on Oct 12, 2010 at 5:41:16 pm
So I had my first card failure. I have been able to "recover" still shots off the camera using a tool called F-Recovery for SD but it apparently doesn't recover video clips. So I know that the images are still on the card but the card is unreadable. Anyone actually used a software tool to recover video clips?
Alf
Mark Alter
Re: SD Card Recovery on T2i - Anyone used software tools successfully?
on Oct 15, 2010 at 10:39:35 am
Hello,
Your card is corrupted and at such situation you have to use a data recovery software for the purpose, you should use Kernel for memory card recovery software to recover all your data either pics or video files very easily and instantly. You can preview the data and files before saving then and check the demo version from -
http://www.memorycardrecovery.org
Alf Hanna
on Oct 18, 2010 at 6:21:26 pm
Well, yes, I knew that. I've already tried a few programs that claim to recover cards. I just loaded up a trial version of Kernal and it did not work at all in even finding files to fix. At least the others I've tried restored some piece of the videos to unuseable JPEG files...So I would not recommend Kernal at all given my experience with it.
Alf
Lucian Smith
on Oct 25, 2010 at 12:57:59 am
Did you end up recovering your video? If so, how did you do it?
Alf Hanna
on Oct 25, 2010 at 1:04:38 pm
No. I still haven't found a software package that can actually recover video .mov files... would love to find one.
Alf
Doog Vandi
on Dec 19, 2010 at 6:00:04 pm
I read in other forums and am trying a software called CardRecovery for win7 (clone of CardRescue for mac)... will post an update. BTW, my card got corrupted because I accidentally switched off the camera while the SD Card reader red light was still blinking.
Doog Vandi
on Dec 20, 2010 at 2:48:59 am
Worked like a charm. Hopefully others can benefit like me from reading this post and other ones such as these on the web.
Doog Vandi
on May 30, 2011 at 12:07:18 am
Funny.. this darn thing happened to me again and I couldn't remember the name of the software I had used last time. I benefited from my own nswer.. haha imagine that.
juan forer
on Feb 23, 2012 at 2:28:03 am
Hey im sorry did u find the software to recover videos??
Simon Claile
on Mar 6, 2012 at 8:55:19 am
Yep, you can recover pictures, videos from SD card with ease. I had managed to retrieve deleted pictures from SD card with a tool called Tenorshare Data Recovery. You can get it from
http://www.any-data-recovery.com/sd-card-recovery.htm
La vita รจ bella.
molicasolis smith
on Apr 22, 2011 at 2:18:38 am
Try Card Data Recovery. It can help you recover SD card data.
http://www.card-data-recovery.com
Al Bergstein
on Feb 23, 2012 at 4:34:04 am
The answer to the question is that I never did recover the card data. Don't lose it, because it does not appear to be recoverable. I tried about every software tool out there.
Al
June Newton
on Aug 1, 2013 at 9:07:06 am
I was having the card error last time also, then I found a sd card recovery tutorial which helped me recover data from the corrupted memory card. here's the guide:
recover data from corrupted memory card
hope this helps.
