can you get a uncompressed output via HDMI from the Canon 5D Mark II while NOT recording?
COW Forums : Canon Cameras
Chris Baldwin
on Sep 29, 2010 at 6:45:50 am
I came across this today.
http://www.atomos.com/
Is there anyway to output an uncompressed 1920x1080 progressive signal from the HDMI port on the canon 5d mark II? I was under the impression that it only output 1080i via the HDMI port while not recording and then switched to SD during recording.
Richard van den Boogaard
Re: can you get a uncompressed output via HDMI from the Canon 5D Mark II while NOT recording?
on Sep 29, 2010 at 7:51:20 am
Interesting question, although I am not sure if this helps...
I was just looking at some videos yesterday from Teradek, who have come up with a system that allows for ad-hoc wi-fi networks. Read the review on PhilipBloom.net. Using a separate recorder would allow you to bypass the issue of resolution-dropping.
cameraman / editor / video marketing consultant
Branded Channels
W: http://www.brandedchannels.com
