Manfrotto LANC and XH-A1s
COW Forums : Canon Cameras
Brian Johnson
on Jul 5, 2010 at 10:47:36 pm
I recently purchased the Manfrotto 523PROi LANC controller for use with my XH-A1s camera. I've found that the zoom response is a bit laggy. I get a much faster response from using the zoom toggle on the camera. Does anyone know if this might be a setting I can change somehow either on the controller or the camera itself?
Brian Louis
Re: Manfrotto LANC and XH-A1s
on Jul 6, 2010 at 10:31:12 am
Hold the zoom speed button until the LED fl ashes and use the wheel to set your speed
Brian Johnson
on Jul 6, 2010 at 9:17:09 pm
The issue I'm noticing isn't with the speed of the zoom, it's the speed in which the zoom kicks in once I push the controls.
Christian Schnabel
on Jul 23, 2010 at 4:35:29 pm
Hi Brian,
is the AF button of Manfrotto 523 Pro working with the XH-A1s? Mine is not but it is working on XM2 camera.
Is there any setting on the XH-A1s to activate it?
