5D MKII files into PAL 25fps - how to... ???
COW Forums : Canon Cameras
Peter Kolarski
on Dec 9, 2009 at 5:58:28 pm
Just today i was testing MKII for some video shooting and its AMAZING but...
I need some of the footage convert into SD/Pal resolution and 25fps. With frame rate it wasn't hard butwhen i put the file into Premiere CS4 and click "scale to fit" the is blure/soapy effetc. The video is far from sharpness (as it is in original file). Is it 'casue the source file is in progressive and output is lower fields?
How can i get sharp clear footage from it into SD???
Thx in advance!
William Busby
Re: 5D MKII files into PAL 25fps - how to... ???
on Dec 10, 2009 at 2:51:37 am
Dunno if this will help (don't shoot with a 5D MKII), but have a look at Philp Bloom's site
http://philipbloom.co.uk/tutorials/canon-5dmkii-tutorials/part-1-importing-...
Peter Wiggins
on Dec 10, 2009 at 9:23:45 am
Easy,
http://www.apple.com/downloads/macosx/finalcutstudio/5dtofcp.html
Droplets for FCS2, FCS2009 on way soon
Peter
William Busby
on Dec 10, 2009 at 10:02:15 am
Right Peter, but the OP is using Premiere Pro. I referenced P. Bloom's tutorial because he initially is using Mpeg Streamclip for the conversion for import in FCP, etc.. Most anyone should be able to figure out in Streamclip what type of file they need to convert to.
