Field issue with HF S100?
COW Forums : Canon Cameras
Fabrizio D'Agnano
on Nov 11, 2009 at 7:44:47 pm
Hello.
I am experiencing what seems a strange problem to me. I own two HF100 an one recently bought HF S100. When I log and transfer from the three cards coming from the camcorders in FCP, and then edit in Prores422, outputting to a lcd video via an Intensity card, everything is fine. Now, when I am done with the editing, and I need to deliver in PAL DV, I copy the edit on a PAL DV sequence, render, and all of the footage coming from the HF100 looks just fine, while the one coming from the HF S100 i jerky. I apply a video shift field effect to -1, render, and it becomes just fine. I tried changing the sequence field order (set it to upper first, and then to lower first), but nothing changes. What can it depend upon? Is there some setting I missed with the HF S100?
Thank you in advance, and best regards
Fabrizio D'Agnano
Rome, Italy
Fabrizio D'Agnano
Rome, Italy
