Menu items in pink
COW Forums : Canon Cameras
Lola Kalman
Menu items in pink
on Jun 14, 2009 at 5:11:14 pm
In trying to change the video dimensions in my GL 2 to 16:9 in the camera set-up menu, several items (Movie Mode, Image S.,AE shift and 16:9) appeared in pink and were impossible to activate. When I tried to select them they only made a feeble beep sound.
Don Greening
Re: Menu items in pink
on Jun 15, 2009 at 7:26:05 pm
Your camera has been set to full auto. Slide the switch back to program mode and you'll be able to access your menu items again. The switch is located on the left side at the back under the AUDIO REC LEVEL switch.
- Don
