Timecode from XHG1 to XHA1 ?
COW Forums : Canon Cameras
Marni Page
on Mar 24, 2009 at 9:21:28 am
Can the XHG1 camera send timecode to the XHA1 for multicam shooting?
Or do you need 2 XHG1's?
cowcowcowcowcow
michael deleon
Re: Timecode from XHG1 to XHA1 ?
on Apr 20, 2009 at 6:57:08 pm
As I understand it, you need two XH-G1s to sync timecode using the Jack Pack studio connectors.
But here's a trick we use to sync timecode on our two XH-A1s. It MIGHT work with an A1 and a G1.
1. Set the cameras side by side and turn them on.
2. Rotate the LCD monitors so that you can see them while standing in front of the cameras.
3. Use the remote from one of the cameras to simultaneously set the timecode on both cameras to Free-Run: Menu > Signal Setup > Time Code> Count-Up
4. Make sure to reset the Start Value to zero.
The timecode will now start counting up continuously whether or not the cameras are recording. Be aware that if you start and stop your recording multiple times, you will have timecode breaks on your tape. If you are capturing in Final Cut Pro, simply set the User Preferences to make new clip on timecode break. This trick has been incredibly helpful to us on multiple occasions. Hope this helps.
-michael deleon
Marni Page
on Apr 20, 2009 at 9:47:29 pm
Wow, Michael. This is a fantastic tip. One I wish I had ages ago. Thank you so much for this.
Marni
