Using a cheap camcorder as a deck (& other questions)
COW Forums : Canon Cameras
Daniel Harbridge
on Mar 14, 2009 at 6:11:51 pm
I'm looking to set myself up as a videographer for a junior sports association this summer. I've been looking into purchasing a decent camcorder because prosumer equipment, as much as I would like to own it, is out of my price range. I've researched up and down through the HDD flash and hard drive camcorders, and found just too many issues be it battery life or editing compatibility with Final Cut Pro. So after days of research, I've ended up where I started, looking at the Canon HV30 as my best option.
The issue for me is that my budget for a full package is in the range of $1500 CDN. A HV30 package will run me around $900. A mini jack mic or XLR adapter pushes me up to $1100 or so (+ a mic if I go the XLR adapter route.) Then I need something to capture the DV tapes with, and a deck is not an option due to the price.
If I'm capturing HD footage shot on the HV30, do I need a camera equivalent to the HV30 to capture on? Or can I use a cheap standard def camcorder to capture with? (i.e. Will I lose resolution? Do I have other options?
Thanks for your help.
John Kert
Re: Using a cheap camcorder as a deck (& other questions)
on Mar 16, 2009 at 4:51:24 am
You can not capture HDV from a DV camera. You may consider the HV20, which is close in specs to the HV30 and may be bought on Ebay for about $550-$600. Then use the HV20 as a playback deck as well since it is cheap. I have the HV20 and like it and use it for cature as well.
© 2018 All Rights Reserved
