HG20: Progressive Segmented Frames?
COW Forums : Canon Cameras
Nayeli Garci-Crespo
on Mar 13, 2009 at 7:09:16 am
Does anyone know for sure if the HG20 records progressive segmented frames or equivalent when set to PF24 or PF30? In other words, even if these are recorded into a 60i stream, after removing pulldown will you get true progressive frames, composed from fields that were from the same instant in time (aside from the rolling shutter issue)?
-Nayeli
