QT 7.6 update undocumented: Canon 5D Mark II movies
COW Forums : Canon Cameras
James Reid
on Jan 23, 2009 at 6:44:29 am
Before you install QT 7.6 read the full post at ProLost
http://prolost.blogspot.com/
Apple released Quicktime 7.6 today, which "includes changes that increase reliability, improve compatibility and enhance security." Sweet. Undocumentedly, it also changes how Quicktime movies made with the Canon 5D Mark II are decoded—for the better.
*image on site
Above is the same 5D clip I wrote about yesterday, back in Color, with Grade Disabled. The clipping is gone. Unlike yesterday, now the waveform is contained entirely between zero and 100 IRE. You'll see this as well in Final Cut and any applications that use Quicktime to decode the 5D movies, such as After Effects.
*image on site
Yay! Problem solved, I guess. This is a scary thing for Apple not to document in an update though, because it will radically change the appearance any 5D clips you're already working with. So update with caution, especially if you're in the middle of a project.
