HD-SDI capturing problems
COW Forums : Canon Cameras
Todd Terry
on Jun 26, 2008 at 6:00:44 pm
Hi gang....
Forgive the cross posting, but I may put this in a couple of forums as I'm not sure where exactly the problem lies.... Canon, Matrox, Adobe, or all of them or everything...
Just as a test I'm attempting to do some capturing HDV source video via HD-SDI and am getting some very weird (and bad) results.
Here are a couple of low-res clips (both the same, just different formats) to show you what I am dealing with:
And here is a full-size screen grab:
As you can see I'm getting stuttery, jerky video with occassional bursts of vertical green lines.
Ok here are the technicalities:
Source test footage was recorded HDV 60i with a Canon XL-H1. I am using this same camera for playback outputting via HD-SDI.
My NLE is a PC, Matrox AXIO LE, in a pretty smokin' fast Boxx computer.
I'm capturing within Adobe Premiere Pro v3.0.
My Premiere project settings are Matrox - HD 1080i 29.97 fps Uncompressed 10-bit. Within Premiere I am capturing as a Matrox AVI via HD-SDI.
I know there is no problem with the tape. If I capture as HDV video rather than uncompressed 10-bit HD video it looks fine. I only see the problem when capturing via HD-SDI, and if I record "live" footage from the camera (not on tape) via HD-SDI I still get the bad results. I have swapped out the SDI cable, with no change.
I'm not in the best "testing situation" as unfortunately I do not have any other way to test the camera's HD-SDI output (I do not have an HD-SDI monitor), and I do not have any other cameras, decks, or other devices that feed HD-SDI so I can't easily test the Matrox HD-SDI input with another source.
I can't tell if it is a hardware, software, or settings problem.... or a combination of several.
Any thoughts or suggestions are greatly appreciated.
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
© 2018 All Rights Reserved
