Canon XL-H1 and JVC HD-110u
COW Forums : Canon Cameras
Chris Ahrens
on Jun 25, 2008 at 5:42:50 pm
I used the JVC HD-110u camera and recorded my footage using 720 24p. My friend has a Canon XL-H1 and I wanted to know if I could use the camera to digitize the 24p HDV footage? Will it cause any problems using a different frame rate?
Also does anyone think it would be easy to match footage shot from the JVC using 720 24p with Canon's 24f? I want to use multiple cameras for an upcoming shoot and these are the only two I have available.
cja
Chris "Topler" Ahrens
http://www.ToplerChampoux.com
402.598.5676
johnny clark
Re: Canon XL-H1 and JVC HD-110u
on Jun 25, 2008 at 9:36:36 pm
JVC is real 24p. Canon is 'blended' 24F (fields). If you can live with the resolution loss than you should be fine in post as long as you convert the canon footage to match the JVC codec or visa versa or just use apple's ProRes. Just make sure they're the same.
Johnny C
Donald Berube
on Jun 30, 2008 at 11:36:04 am
You cannot use the XL H1 to play back JVC HD-110u footage or vice-versa. You'll need the actual camcorder which the footage was captured on to play the footage back and capture from.
- Don
http://noisybrain.com
http://www.bosfcpug.org
