XL1 Black Corners
COW Forums : Canon Cameras
Frank Bruno
XL1 Black Corners
on Apr 29, 2008 at 1:35:02 pm
Hi, I am seeing black corners on the video I shot with an XL1.
It looks like a big circle instead of square frame. It doesn't show up within the TV safe area but I know it shouldn't be there.
Frank
Jim Tuchschmidt
Re: XL1 Black Corners
on Apr 30, 2008 at 2:16:41 am
Without seeing exactly what you see, I suspect the most probable cause is the sunshade. If you open the lens wide, you may get dark corners because the very edge of the sunshade is in your frame. This is why Canon supplies a special sunshade with the wide angle lens for the XL1.
Jim
Frank Bruno
on Apr 30, 2008 at 12:28:19 pm
Jim, I tried that. I'm seeing the black on tight shots. Its fine on wide shots. I need to post a screen capture for all to see.
