Editing 16:9 DV
COW Forums : Canon Cameras
Pouyan Fard
Editing 16:9 DV
on Apr 2, 2008 at 3:48:19 pm
Hello
I just shot something with my Canon A1 in the DV 16:9 mode. When I bring the footage in Final Cut pro everthig is streached.
How should I set my sequence so I can edit in 16:9 mode
any help is appreciated
thanks Pouyan
Don Greening
Re: Editing 16:9 DV
on Apr 2, 2008 at 5:58:58 pm
If you shot in NTSC then use the DV NTSC Anamorphic sequence preset. If you shot in PAL then use the PAL Anamorphic sequence preset. Make sure the Anamorphic box is checked in the setup window.
- Don
