Question about TC syncing the XL-H1 and XH-G1
COW Forums : Canon Cameras
Howard Brodsky
on Feb 3, 2008 at 1:25:09 am
Both of these cameras have jack packs for genlock and TC synchronization. I have both cameras set for HD 1080/60i in drop frame and rec run modes. I've got a single SDI/BNC cable going from the XL-H1's TC out to the XH-G1's TC in.
Should I set the XL-H1 for int user bit and the XH-G1 for ext user bit?
Can I disconnect the cable after these cameras handshake and still maintain TC sync?
Howard Brodsky
Re: Question about TC syncing the XL-H1 and XH-G1 (Followup)
on Feb 3, 2008 at 8:06:12 pm
Followup,
Both cameras were actually set to int user bit. I assume there is some automatic priority over-ride involved in the time code syncing process. The two cameras synced up perfectly. I removed the cable and the XH-G1 was still in sync with the XL-H1.
This was just to test out the system and I had a test tape in the XL-H1 which ran out. The XH-G1 still continued with the same "synced" time code stream. Even after I turned the XH-G! off, when powered up it was still in the same "synced" timecode stream! Even after I removed the battery and replaced it - the XH-G1 was still in the same "synced" timecode stream!
I created a monster that has run amok! How do I stop this thing?
Donald Berube
on Feb 9, 2008 at 5:04:35 pm
Howard,
Thank you for your follow-up.
- Don
DONALD BERUBE
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
