HG10
COW Forums : Canon Cameras
Vinnie75
HG10
on Jan 5, 2008 at 9:47:29 pm
I saw a review on it while watching G4TV Attack Of The Show. They mentioned it was only 800 dollars, but the site has it at over 1000 dollars.
We use a JVC at work, and an old Sony Betacam.
How does Cannon work with APPLE FCP? I've been told by a few that some cameras work better with different operating systems.
And will the HG10 still tape in SD mode for some of the clients who still have SD dvd players?
Thanks for any info,
Vinnie
cowcowcowcowcow
Donald Berube
Re: HG10
on Jan 10, 2008 at 7:32:58 pm
The HG10 records High Definition only (no Standard Definition available) as a file to an internal 40GB hard drive using the AVCHD Codec. 4 different levels of recording quality are available, each with unique hard disk space requirements. At 15mbps "Best Quality" you can record 5 1/2 hours of HD video. Again, no Standard Definition video recording is available.
You transfer the AVCHD clips from the HG10 via USB2.0 to your computer hard drive for editing. With FCP Log & Transfer Mode, you have a choice of ingesting the clips using either the Apple Intermediate Codec or the new ProRes422 Codec. That means that you don't edit in FCP using the AVCHD Codec - you have a choice between the two aforementioned Codecs to use as your editing Codec... With iMovie the clips are ingested using the Apple Intermediate Codec.
Hope this info helps,
- Don
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
Vincent Strader
Re: HG10
on Jan 15, 2008 at 4:57:26 pm
A friend of mine told me that it didn't matter if the camera only taped in HD. He said FCP can convert HD to SD for those clients that still want SD DVDs. I've never worked with HD, and he's never worked with FCP. So I'm just wondering if it's as easy as he says it is?
Vincent Strader
Re: HG10
on Jan 15, 2008 at 4:58:42 pm
Woops, sorry about the FCP question. As I read the response I was in a FCP mind set so I thought I was replying to my post in the FCP forum. I'll ask them.
Vinnie
