XL2 Time Code Sync Issues
COW Forums : Canon Cameras
James Ho
on Dec 3, 2007 at 2:42:25 am
I have a problem with syncing two XL2s using Free run timecode set through the wireless remote control on both cameras. I followed the instructions exactly from the article below:
http://www.dvinfo.net/canonxl2/articles/article11.php
I am using FinalCut Pro 6 to capture and log from tape.
The problem is, one camera always seems to run faster than the other. Can anyone advise, what I should try? According to the article this was supposed to be a fool proof way of syncing time code.
James
Donald Berube
Re: XL2 Time Code Sync Issues
on Dec 6, 2007 at 3:41:57 pm
I know this might sound like a dumb question,,, but I gotta ask: are both XL2's set to the same Frame Rate? (60i, 30P or 24P?)
- Don
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
James Ho
on Dec 14, 2007 at 2:10:03 am
Yes, both XL2's are the same frame rate at 60i.
James Ho
on Dec 25, 2007 at 1:03:29 am
I called Canon Tech Support and they suggested that one of the cameras is out of alignment on playback speed so they suggest bringing both cameras in for maintenance.
