Using XH A1 HDV down convert to standard
COW Forums : Canon Cameras
ifraser
on Nov 24, 2007 at 10:38:49 pm
I am trying to convert my HDV footage to Standard on to the Mac computer using FCP 6. I looked on the manual pg 109 and did the set up. I have it on VCR mode and going through the menu. When I plugged the firewire cable into the camera both the PLAYBACK STD and HD DOWN_CONV grayed out and was not able to use the function. I unpluged the firewire cable and it showed up and was able to modify it. Not sure what I missing here. It also did the same thing on my other computer a PC.
Hope this was enough info thanx
WilliamBusby
Re: Using XH A1 HDV down convert to standard
on Nov 26, 2007 at 3:08:27 am
You make your settings after you disconnect the firewire cable & then reconnect it. Voila!
Stupid design, but it is what it is.
Bill
Donald Berube
on Dec 8, 2007 at 4:03:59 am
FYI, the down-converted output signal will always be 60 fps interlaced (29.97), regardless of the frame rate of the original recording.
- Don
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
