Using Compent out of the XL H1??/
COW Forums : Canon Cameras
hdfilmmaker
on Oct 10, 2007 at 10:51:37 pm
What kind of signal or image size do I get when I use the supplied HDMI breakout cable from the XLH1? too take a compent signal into FCP? Does anyone use this for capturing?
Is that the color red you want to use?
Donald Berube
Re: Using Compent out of the XL H1??/
on Oct 11, 2007 at 3:07:00 pm
The Component output of the XL H1 outputs an Analog Component Y(Green), Pb/Cb(Blue), Pr/Cr(Red) 4:2:2 29.97 1080i signal.
- Don
http://noisybrain.com
http://www.bosfcpug.org
hdfilmmaker
on Oct 11, 2007 at 3:11:08 pm
BUt that is not as good of quality as SDI? I have the KONA LH card. I can not find which connector on the card is for SDI.
Todd at Fantastic Plastic
on Oct 11, 2007 at 5:22:42 pm
[hdfilmmaker] "BUt that is not as good of quality as SDI? I have the KONA LH card."
HD-SDI is going to be the way to go, if you can.... although I kinda doubt your eyeballs would be able to tell if it is much superior to component.
I'm guessing you don't have the AJA KONA breakout box... which has direct HD-SDI BNC connector inputs and outputs on it...that's the way we injest XLH1 video. Without the breakout box, I'm not sure how you can get HD-SDI into the KONA card. You might ask that over in one of the AJA forums.
Even if you can get HD-SDI video straight into the card, you might look into getting the breakout box just for convenience sake (it's a slim rack mount box with bunches of BNC connectors, XLR audio ins and outs etc... and connects straight to the card with two cables). It's not very expensive, if I recall.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
