Wing-flap Ghosting
COW Forums : Canon Cameras
kayacroix
Wing-flap Ghosting
on Sep 28, 2007 at 1:49:43 pm
I am experiencing a "ghosting" problem on footage of the flapping wings of birds, from my XH-A1. The shutter speed was at 1/500 f12, which I thought would have been plenty fast enough.
I have captured in both NeoHD and Vegas7---same ghosting result.
I have viewed this on both my LCD and my TV ext. monitor.
I have tried to eliminate by switching to progressive field, but no luck.
Is this fast motion a limitation of the XH-A1? Or, it this, once again, "pilot error" of some sort?
Donald Berube
Re: Wing-flap Ghosting
on Oct 1, 2007 at 2:39:43 pm
f12 is too small of an aperture to use with a 1/3" sensor in general... you most likely should have utilized the built-in Netral Density to limit the light going through the lens and perhaps used a shutter speed no higher than 1/250.
- Don
DONALD BERUBE
http://noisybrain.com
http://www.bosfcpug.org
kayacroix
on Oct 2, 2007 at 12:57:43 am
The camera was on autopilot when these settings occured. I will not make this mistake twice.
Do you believe that these extreme settings would explain this double exposure of fast moving objects, like flapping wings?
Thank you for your reply.
