Best setting to get the least amount of grain in low light?
COW Forums : Canon Cameras
Javicbr600
on May 11, 2007 at 3:30:28 am
What do you think are the best setting to get the least amount of grain in low light on a canon a1? What settings should I mess with or set diffrently?
Donald Berube
Re: Best setting to get the least amount of grain in low light?
on May 17, 2007 at 2:25:54 pm
Turn ON a Custom Preset. Edit that Custom Preset and adjust the following:
CORING: +8
NR 1: LOW
NR 2: OFF (If you are on a static shot on a tripod with not much movement in the frame, then set to LOW)
Boost the Croma a bit too, so that you are getting a healthy color sample.
Feel free to activate Cinema Gamma with a Low Knee if you want a more film-like look. Set Blacks to STRETCH. Keep SETUP and PEDESTAL at 0 or possibly +1.
Keep the VIDEO GAIN to -6 or under if possible (use +12db if you absolutely must...)
Try decreasing shutter speed from 1/60sec to 1/30sec before boosting gain to +12db.
Be careful about using 1/24sec in 24F mode as you will see a lot of motion blur...
Please do let us know if you have any other questions.
- don
http://www.bosfcpug.org
http://noisybrain.com
