Best way to record some voiceover?
COW Forums : Canon Cameras
kevin c.
on Aug 26, 2006 at 10:10:26 pm
I have an audio technica mike and could record to mini DV.
But is there a good option to record straight to hardrive?
That's where it ends up anyway.
thanks
G5 - MAC 10.4.7
Matte
Re: Best way to record some voiceover?
on Aug 27, 2006 at 4:39:36 am
Continue to use the camcorder and tape it to DV,
You'll have a time-coded back-up that you can store,
eyecamiam
on Aug 27, 2006 at 4:30:57 pm
Yes. There are USB interfaces that allow you to plug in mics and there are USB mics that plug in directly. One advantage to recording on your cam is you have a visual reference of what was recorded. On the other hand, most camcorders do not have audio components as good as dedicated equipment.
Matte
on Aug 29, 2006 at 12:10:43 am
[eyecamiam] "On the other hand, most camcorders do not have audio components as good as dedicated equipment."
Having been in this business for a few decades, I can tell you that the audio section in the cheapest digital camcorders is leaps and bounds better than the finest analog studio gear that used to be considered state-of-the-art.
Under 98% of "finished product" mixes, the camdorder audio will be just fine.
If you need better than that, you wouldn't have a mic and studio facilities at your disposal at this end of the spectrum anyway.
That's why, all things considered, the "record-to-camcorder" audio method is likely the better option.
HatkowProductions
on Sep 2, 2006 at 7:52:31 pm
Hey again Kevin, also a little trick I use (I agree, use the cam) Figure out your dialogue and take your cam and mic and go sit in a car/truck/van in a closed garage. Automobiles have pretty good sound deadening built in and a closed garage adds to that. I haved used this technique many times and people have asked how I did it! Easy easy.
