proper way to setup for editing frame mode?
COW Forums : Canon Cameras
Shayne Weyker
on Aug 22, 2006 at 12:53:11 pm
Hi.
I have Premiere Pro 1.0 and a cannon GL2. I want to eventally get used to shooting stuff in 30p frame mode when I know its destined for the web so I can save on the deinterlacing when encoding to WMV/MOV/FLV.
So I wanted to try capturing some footage shot in the GL2 Frame mode.
I set up a Video for Windows project, 30 fps, no field first/progressive, 30fps timecode.
And then captured manually after I start playing the tape.
But what I read in a previous message here seems to say should I just set up the project and capture like it was plain NTSC-DV. Is that the right way?
And when I'm done what's the best format to export in to set up for web encoding? Uncompressed AVI?
--Shayne Weyker
Donald Berube
Re: proper way to setup for editing frame mode?
on Aug 23, 2006 at 3:21:41 pm
The firewire output of the GL2 is a 29.97 NTSC DV stream regardless if you shot in normal Movie Mode or Frame Mode.
Simply edit it as 29.97.
Best of luck,
- don
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
