Best way to grab some audio
COW Forums : Canon Cameras
kevin c.
on Aug 9, 2006 at 11:36:17 pm
I'm director. If I need to grab some new audio dialogue, should I do it with my GL1 and my audio technica mike on mini DV, or would it come out just as good with my handheld mini disc recorder on MD? thanks
Donald Berube
Re: Best way to grab some audio
on Aug 10, 2006 at 5:37:52 am
Something tells me that you may have slightly better mic preamps and audio leveling, in addition to more frequency range, on the GL1 than on the handheld mini disc recorder. It could be said that the difference between the two is negligible?
The benefit of using the mini disc recorder is that you will have quicker random access to your sound bites (less time spent searching for gems)
- don
http://noisybrain.com
http://www.bosfcpug.org
http://fcpugnetwork.org
Thax
by
on Aug 10, 2006 at 1:35:46 pm
[Donald Berube] "The benefit of using the mini disc recorder is that you will have quicker random access to your sound bites (less time spent searching for gems)"
But the benefit of shooting to DV is that it will already have Timecode, will be easier to capture, and can be stored with the other master tapes for future reference.
Donald Berube
on Aug 10, 2006 at 4:36:00 pm
Exactly.
I would record to the GL1 versus the mini disc.
- don
kevin c.
on Aug 11, 2006 at 12:15:25 am
thanks guys, it's so much faster to mini disc, than having to set up XLR converter, mike etc, but of course I'd have to convert the MD to CD (anologue maybe) as editors can't input an MD.
