GL2 (manual doesn't state the frame rate)
COW Forums : Canon Cameras
Mike James
on Jan 22, 2006 at 1:51:54 pm
Page 50 for "Movie Mode (Normal/Frame)" .... mentions nothing about what the actual FPS is under this mode. I can't find any other mention about this frame mode in the manual. Anyone?
Mike James
"FRAME MODE"
on Jan 22, 2006 at 1:54:10 pm
Just so I a little more clear... it is the FRAME MODE that is unclear to me. Obviously normal is standard NTSC.
Don Greening
Re: "FRAME MODE"
on Jan 23, 2006 at 4:47:07 am
Frame mode combines the two interlaced fields into one before it's recorded to tape. The popular belief is that a considerable amount of picture resolution is lost with this method. Frame mode is not progressive scanning, which records one complete picture for every frame without having to combine the interlaced fields. Progressive scanning is not possible without using progressive scan CCD's, which the GL2 does not have. Frame mode on the GL2 is recorded at 30fps.
- Don
Mike James
on Jan 23, 2006 at 2:55:55 pm
Thanks Don
Mike James - VFXpodcast.com
Avid Xpress Studio ::: DFX+5 ::: Cinema 4D 9.5 XL Bundle ::: ProTools 7 LE
