Canon XL2 flickering images
COW Forums : Canon Cameras
macclassic44
on Oct 16, 2005 at 5:17:37 pm
Hi chaps,
Anyone know the answer before I contact Canon. I use a 20in iMac to edit in FCP, but the problem I am getting appears to be an interference pattern around moving edges, whether camera panning or movement of objects in the frame. On a low value preview in BTV, the problem is chronic. Is this the camera, or the monitor, or what. A significant vestige of the effect persists when monitored on SVideo with a direct feed from the camera to a TV.
Rod
Matte
Re: Canon XL2 flickering images
on Oct 16, 2005 at 7:33:32 pm
[macclassic44] "A significant vestige of the effect persists when monitored on SVideo with a direct feed from the camera to a TV."
Well, that would be a CAMERA problem.
(If it does this on any TV monitor you connect it to.)
