High Quality DVD Slideshows
COW Forums : DVD Authoring
Thomas Hanser
on Nov 14, 2016 at 8:52:50 pm
So...if DVD only supports 720x480, how can I render and burn a DVD slideshow if my timeline is 1920x1080?
Most TV's are much higher resolution than 720x480, obviously. And my first test burn looked terrible scaled up on a flat panel TV. Obviously that won't work.
I created the slideshow using very high-res Photoshop files in a 1920x1080 timeline sequence. But this is scaled way down in Roxio Toast, resulting in a useless presentation for large TV's.
(I'm a little out of practice in terms of authoring DVD's - all my work goes on the web these days.)
Thomas Hanser
Seattle, WA
Jeff Pulera
Re: High Quality DVD Slideshows
on Nov 15, 2016 at 4:05:29 pm
DVD is a specification, and that spec is for standard-definition video only (720x480). If you want HD video on a disc, then you would make a Blu-ray disc instead.
Perhaps a better option - export an HD file using H.264, resulting in an .mp4 file. Save to a USB thumb drive stick. Plug USB stick directly into TV. Play HD video. Some Blu-ray and DVD players also now have USB ports, same thing, plug and play with stick.
Jeff Pulera
Safe Harbor Computers
Thomas Hanser
on Nov 15, 2016 at 8:40:13 pm
Thanks, Jeff.
Playing an .mp4 file from a thumbdrive sounds like the only answer! ?
Thanks again.
Thomas Hanser
Seattle, WA
