Problems with Handbrake
COW Forums : DVD Authoring
Sejin Kim
on Nov 10, 2016 at 2:07:43 am
I am trying to pull off footage from a DVD. There are two folders on the DVD: OpenDVD and the standard VIDEO_TS. When I try to use Handbrake to pull that footage off, it pulls off the first 30 seconds or so flawlessly, then simply stops and calls the encode job done. It sees that there is 33 minutes of footage (which is correct), but it only encodes the first 30 seconds.
I've tried on both a Mac and a PC, both running the latest version of Handbrake, but all with the same results.
Any suggestions? (I'd prefer to use Handbrake, although software suggestions are acceptable)
Alexander Kallas
Re: Problems with Handbrake
on Nov 10, 2016 at 9:28:33 am
You need another App, Handbrake won't do it.
Cheers
Alexander
Sejin Kim
on Nov 11, 2016 at 12:05:34 am
Do you mind sharing your favorites?
Alexander Kallas
on Nov 11, 2016 at 8:26:42 am
Start with " Mac the Ripper"
Cheers
Alexander
Jesse Simon
on Nov 19, 2016 at 7:47:43 am
Recommend a Handbrake Alternative to you. I found this solution just because the HandBrake only rips part of my DVD. And this page list the problems you may encounter and you are able to find solution here.
