DVD Architect Playback Issue on Single Title
COW Forums : DVD Authoring
Steve Mason
on Sep 14, 2015 at 10:42:01 pm
I authored a DL disc in DVDA 5.2; all titles, menus, etc. work flawlessly, with the exception of one title. For whatever reason I only have this issue with one player which is about 5 years old and fairly high-end as players go (part of home theater system.
I am puzzled as to why this one title is causing the player to freeze when all the others play fine.
Any suggestions would be greatly appreciated.
Daniel Ludwig
Re: DVD Architect Playback Issue on Single Title
on Sep 16, 2015 at 6:12:47 pm
Hi Steve,
I´m not an DVDArchitect-user, but DVD-9 in general has several problems with standalone-players, so there´s nearly no doubt that it´s a DVD-/+R-media-problem.
I have seen many problems on several players especially with the layerbreak-position and the content that comes afterwards (meaning which lays on layer1).
1. layerbreak-position
if you did not create a dedicated disc-image before burning, there might be the problem with the layerbreak-position. most burning-apps will set the layerbreak-postion at the real physical end of layer0, which is wrong in most cases. In case you´ve got a disc-image, you should be ready to burn the data.
2. reflection of layer1 of the optical media.
all DVD+/-R-media have a different reflection (lower reflection-output) from the disc, and especially on the 2nd layer. it could result on a problem while re-focussing on the 2nd layer or reading the data.
3. bitrate
high bitrate could also result in playback-issues. it´s highly recomended to use lower should use a max. bitrate of 8,5Mbit/s or less.
should this DVD be replicated?
© 2018 All Rights Reserved
