Burning a Dual Layer DVD
COW Forums : DVD Authoring
Steve Mason
on Jul 3, 2015 at 5:21:14 am
Hello,
I'm in the final phases of authoring an intricate DVD, which due to the sheer amount of data it holds must be dual layer. This is to be an instructional and set-up disc, which will accompany a tangible product.
Further, this is a start-up product; my initial goal is to achieve placement with a few re-sellers by sending out a handful of "beta" DL-DVDs to interested prospects for review. Due to start-up budget constraints and the strong probability of changes to the DVD before wide release, I'd prefer not to invest the approximate $1500.00 on a replication run right now.
I am using DVD Architect 5.2 for this task; I've been compiling and burning iterations of the project for testing as the build develops. The burned discs have thus far worked fine on newer DVD players, including portables; however the same discs have exhibited issues on somewhat older devices, i.e. 5-6 years old.
Short of the obvious (biting the $1500.00 bullet), are there any recommendations for maximizing compatibility in terms of method, e.g. compile in DVDA and use ImgBurn to set the break point and burning, etc. - just to get up and running?
Any expert advice is tremendously appreciated.
PS - When it is time to go to replication, any advice for this same project would be equally appreciated.
Steve M.
Steve Brame
Re: Burning a Dual Layer DVD
on Jul 3, 2015 at 3:07:59 pm
Haven't done much DVD authoring in quite a while, but back when it was our main delivery media, I remember that most player incompatibility problems were due to the brand of media. Where we'd have a compatibility problem on one player, simply burning to a different brand of disc would take care of it, but possibly result in incompatibility elsewhere.
It got to the point that we created a standard waiver advising a client to use replication rather than duplication, and that failing to do so released us from liability of any player incompatibility claims.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive - WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) - WD Velociraptor 10K drive 600GB * Media Drive - 2TB RAID0 (4 - WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
"98% of all computer issues can be solved by simply pressing 'F1'."
Steve Brame
creative illusions Productions
Rob Neidig
on Jul 6, 2015 at 4:41:36 pm
In addition to what Mr. Brame said, I would recommend not using dual layer DVDs at all. No matter what brand disc you use to burn, dual layer discs have compatibility issues on a lot of players. You are far better off splitting your project onto two discs. Even if you are replicating, dual layers can be an issue.
Have fun!
Rob
Rob Neidig
R&R Media Productions
Eugene, Oregon
