Simple Blu ray dvd creation
COW Forums : DVD Authoring
Mark Slocombe
on Nov 30, 2013 at 10:47:49 am
Hi, at the end of yesterday my client advised I will likely need to make a blu ray version of the 3 minute video I'll output as a 1920x1080 h264 mp4 that they'll play on screens via a USB stick - our usual route.
The project is in FCP x, my iMac is super-spec, inc Thunderbolt; I have authored in DVD Studio Pro for years, but I have no bluray authoring programme ( unless Compressor will ) or burner.
The bluray will be a simple autoplay, no menu.
Can anyone recommend my quickest, easiest, most reliable solution for Monday? What software and what burner.
Mark Slocombe
http://www.creationvideo.com
London, England
Daniel Ludwig
Re: Simple Blu ray dvd creation
on Nov 30, 2013 at 4:25:19 pm
FCP X could create a "viewing-copy" styled BD, but you wont be able to select between these two films within a menu.
they all need to be present in one! timeline.
if you would like to have a menu, where you can select one of these, you should use toast 11 + HD-plugin.
with toast you can create easily a blu-ray with a simple menu.
danny
Mark Slocombe
on Nov 30, 2013 at 5:06:48 pm
Thanks Danny, I only have one 3 minute film so no menu / chapters required. I'm not in the office to check, but thought FCP x only had sd DVD output - would I simply select the DVD option in FCP x Share menu, and burn on the Samsung bluray burner I ordered today?
Mark Slocombe
London, England
Daniel Ludwig
on Nov 30, 2013 at 5:19:49 pm
marc,
you should only use the share-function.
press the "add destination"-button and add the blu-ray to your share-option.
far tooo easy ;)
danny
Mark Slocombe
on Dec 1, 2013 at 12:24:28 am
Cheers - easy is ok by me sometimes ;-)
Mark Slocombe
London, England
Mark Slocombe
on Dec 1, 2013 at 3:49:39 pm
Hi again - just looking at FCP X Share dialog - I see the Blu-ray option… the iMac's internal SuperDrive is listed as an output device - does that mean the SuperDrive is able to burn a Blu-ray disc? I had assumed I'd need a dedicated external Blu-ray burner?
Mark Slocombe
London, England
Daniel Ludwig
on Dec 1, 2013 at 8:05:24 pm
you can burn AVCHD-discs on DVD, but if you would like to have a dedicated blu-ray, you should buy a BD-burner.
cheers
danny
