Converting DVD to youtube format?
COW Forums : DVD Authoring
David Lord
on Jul 17, 2013 at 1:08:56 am
Hi everyone, sorry if this isn't the right forum to post this in. I have some old projects from Adobe premiere on DVD, and I no longer have any of the original project files. I want to know if there's a way to copy them and change them to a format appropriate to upload to youtube. Thanks in advance!
Jeff Pulera
Re: Converting DVD to youtube format?
on Jul 17, 2013 at 2:08:12 pm
Hi David,
Copy the .vob files from the DVD to a hard drive on the computer, then Import those files into Premiere and put in a Sequence. Edit if need be, and then Export using an H.264 YouTube preset.
Jeff Pulera
Safe Harbor Computers
David Lord
on Jul 17, 2013 at 2:33:03 pm
cool thanks! that sounds easier than I expected. but isn't h.264 a high definition format? these are some old videos I recorded on mini dvr.
Jeff Pulera
on Jul 17, 2013 at 2:53:31 pm
H.264 is whatever resolution you need it to be, it not an HD format specifically.
Jeff Pulera
David Lord
on Jul 17, 2013 at 3:25:06 pm
sorry, last question. would there be any benefit to exporting in h.264 over MPEG 4? that's always what I used to export in.
Jeff Pulera
on Jul 17, 2013 at 3:27:14 pm
No, MPEG-4 has very limited options for export. Definitely look under H.264 and there are several YouTube presets when you scroll down, I believe they do have a "YouTube SD" preset, just use that.
Jeff Pulera
