Continious Looping with Compressor?
COW Forums : DVD Authoring
andrew thompson
on Jun 26, 2013 at 4:48:16 pm
Hello everyone,
Is it possible to create a DVD that will continuously play in a loop using Compressor? My source is a 7 minute quicktime. Thanks in advance for any info!
eric pautsch
Re: Continious Looping with Compressor?
on Jun 26, 2013 at 7:23:06 pm
Compressor doesn't author a disc, it only encodes
Make your mpeg from compressor and bring it into DVDSP and set the movies end jump back to itself
David Eaks
on Jun 27, 2013 at 4:54:04 am
Hi Andrew,
Many DVD players have this function, do you have control of what player is used? If not, do you have DVD Studio Pro?
Eric says-
"Compressor doesn't author a disc, it only encodes"
Sure it does. It's in the Job Action menu in the inspector. Though it may be extremely limited in customization options. It does Blu-ray as well. The DVD could be set to play on insert and the DVD player set to loop play.
andrew thompson
on Jun 27, 2013 at 5:24:37 pm
Thanks for the replies fellas. I wound up exporting my sequence from Premiere in MPEG2 then importing into Encore. From there I was able to encode a DVD to loop back to the beginning once it reaches the end.
