If you put a Pal DVD in the Tower, do you get PAL DVD copies?
COW Forums : DVD Authoring
Steve Garman
on May 15, 2013 at 2:28:20 am
I'm guessing the answer to this is obvious, but since I can't check them I'd just like to be absolutely sure.
Steve
Jeff Pulera
Re: If you put a Pal DVD in the Tower, do you get PAL DVD copies?
on May 15, 2013 at 2:21:34 pm
Hi Steve,
A DVD recorder is neither PAL not NTSC, it just records DATA. Whatever is on the disc will simply be copied.
Jeff Pulera
Safe Harbor Computers
