Can you combine upper and lower field sd video on a dvd?
COW Forums : DVD Authoring
Dennis Stimac
on Apr 18, 2013 at 8:03:58 pm
I have some hd down-converted to sd upper field first and some sd lower field footage i'd like to combine together on a dvd. The upper field is for the main title and the lower field video is for the menu background video only.
I know I could de-interlace the menu video and re-render as upper field, but id rather stick with the master copy settings as-is, if I could.
Could this cause potential playback or viewing issues on some dvd players or does it not matter?
I plan on distributing copies of this video and wouldn't want any incompatibility.
Thanks in advance.
eric pautsch
Re: Can you combine upper and lower field sd video on a dvd?
on Apr 18, 2013 at 8:50:10 pm
You're fine as long as its not in the same title (track)
