Have used Compressor; can I now use Toast to make a DVD?
COW Forums : DVD Authoring
Vic Noseworthy
on Feb 27, 2013 at 9:24:18 pm
Hi folks,
I have just used Compressor to create the two files I need in order to make a DVD. However, DVDSP won't recognize my external La Cie DVD burner (and my internal burner doesn't work). I do have Toast Titanium and am wondering can I use the files created with Compressor to make the DVD.
Note: I have tried using the .mov file directly into Toast, but the quality isn't good. I thought that if I used the Compressor files, I might get better quality.
Any help would be very much appreciated.
Vic
Daniel Ludwig
Re: Have used Compressor; can I now use Toast to make a DVD?
on Mar 1, 2013 at 4:32:44 pm
Vic,
use video>dvd video
drag&drop the m2v-file.
within the advanced feature deactivate the re-encoding-option and make sure these files have the same name like
file.m2v
file.ac3
then it just will multiplex them and wont reencode.
cheers
danny
