Specifically within Adobe Encore
COW Forums : DVD Authoring
Peter Groom
on Jan 30, 2013 at 2:26:21 pm
I s there a way of amending a Blu Ray or DVD compliant file (made in Sorenson Squeeze INSIDE encore.
eg. I make a video, make the files in sor sq and import and author insode encore. THEN i get an amend to a shot in the middle.
Id LIKE to be able to export just that bit, whack it through sor sq and then drop it into the encore timeline as an edit and have the audience non the wiser.
Can this be done. Sometimes its hours to recreate long files for a tiny change.
Post Production Dubbing Mixer
Daniel Ludwig
Re: Specifically within Adobe Encore
on Feb 7, 2013 at 2:55:48 pm
what you are looking for is segmented based reencoding! this could only be done with high-end-encoding-software like rovi totalcode or CCE HD for a lot dollars.
otherwise you need to encode the entire timeline all the time.
© 2018 All Rights Reserved
