Alternative to Adobe Encore in PC
COW Forums : DVD Authoring
Francisco Bech Gómez
on Dec 10, 2012 at 5:37:19 pm
Hello, I had a problem with my Imac DVD recorder and I have to use a PC to create a DVD out of M2V and waw files. I did the conversion with premiere and use Encore to make DVDs. I been triying Nero and other programs, but I cant find one to work with these files. Is there something reliable like Toast or Encore I can use in a PC?
best regards
eric pautsch
Re: Alternative to Adobe Encore in PC
on Dec 10, 2012 at 9:31:26 pm
The problem isn't the authoring tool but the files you are giving it. How are you encoding?
on Dec 13, 2012 at 6:49:19 pm
My PC is not 64 bits and I can Install Encore. I have the m2v and waw files created in premiere in my Imac ,
what software can I use with a PC to create a DVD with those files, I tried Nero with no results
best regards
David Rehm
on Dec 14, 2012 at 7:08:36 pm
You can create the DVD pretty easily with Encore. Encore needs Mpeg2 files. Or if you are able to use Dynamic Link (depending which version you have - it always helps others to help you when you list the software version you are working with - it makes a big difference) and bring in the Premiere Pro sequences and let Encore do the transcoding.
David R.
