What's Causing Jitter?
COW Forums : DVD Authoring
Thomas Hughes
on Dec 7, 2012 at 10:43:59 pm
We edit on Final Cut. Whenever we need the finished program on a BluRay disc we use Toast. It generally works fine and looks good, but I just completed one that doesn't look good. Shots without movement look wonderful but whenever there's movement (camera or subject) there's terrible jitter. Is that a setting in Toast? If yes, how do I fix it? tx
Thomas H
Andreas Gumm
Re: What's Causing Jitter?
on Dec 7, 2012 at 11:37:48 pm
It seems the footage has wrong field order on output.
It must be top field first.
Andreas
Andreas Gumm
selfemployed media author
Thomas Hughes
on Dec 7, 2012 at 11:48:17 pm
Is that a setting in Toast? If yes, where? Thank you.
Thomas H
Andreas Gumm
on Dec 7, 2012 at 11:50:17 pm
I don't know,
I don't work on a Mac! ;)
Andreas Gumm
Gary Milligan
on Dec 8, 2012 at 12:53:37 am
How are you exporting out of Final Cut?
Thomas Hughes
on Dec 8, 2012 at 4:52:40 pm
We export with QuickTime to get the program into an .mov file. We use the settings Edit to Tape Apple Intermediate Codec 60.
Then we drag the .mov file into Toast.
Thomas H
Gary Milligan
on Dec 10, 2012 at 5:37:52 pm
Sorry for the delay in responding.
[Thomas Hughes] "We use the settings Edit to Tape Apple Intermediate Codec 60."
I'm confused by this - I don't understand why or where in your workflow you use the Edit To Tape function. Apple Intermediate Codec is a poor choice.
[Thomas Hughes] "We export with QuickTime to get the program into an .mov file."
To get the best quality QuickTime Movie export out of Final Cut use the 'Current Settings', DO NOT select 'Recompress All Frames', and DO select 'Make Movie Self-Contained'. This will make an exact duplicate QuickTime file of your timeline using the same codec used in your sequence settings (what are your sequence settings?). Don't export 'Using Compressor' or 'Using QuickTime Conversion' - doing this will recompress your timeline sequence. I'm guessing that somewhere in your workflow you've done some recompressing and introduced a field order change.
HTH
Gary
Peter Groom
on Dec 21, 2012 at 9:49:46 am
is your media / seq upper filed 1st or lower.
there is a filter in FCP called de interlace. Try this
You can eliminate the frustration and time wasting of exporting and making costly discs by having a tv monitor (not a computer screen) attached to your edit so you will see field issues before you make a dvd or blu ray.
Peter
Post Production Dubbing Mixer
Michael Sacci
on Dec 21, 2012 at 2:06:22 pm
De-interlace filter throws away 1/2 of your image. Quality is degraded.
