Removing HVDVD_TS Folder in builds location
COW Forums : DVD Authoring
Karina Louw
on Nov 25, 2012 at 5:11:06 pm
Hi there,
I recently reinstalled FCS3 - and by accident I must have selected HD video standard when i launched DVD Studio pro for the first time. I realized my mistake when I burned a dvd and it would play in DVD player or my computer (although it worked fine in simulator). So in the preferences window I changed it back to SD dvd - but when i pressed the burn button again (after re-authoring dvd with SD setting) the following message appeared:
"The Build Location folder contains a HVDVD_TS folder(HD DVD content). You must remove the HVDVD_TS folder from the Build Location in order to proceed with Build/Format of a Standard DVD project"
Sorry if this is a stupid question but - how do I do this? Any help will be greatly appreciated.
K
Bill Stephan
Re: Removing HVDVD_TS Folder in builds location
on Nov 26, 2012 at 5:39:39 pm
Just navigate to the location set in DVDSP as the build folder, then take the HDDVD_TS folder you find there and drag it to the trash (or recycle bin). Then you will be good to go. DVDSP will put a new VIDEO_TS folder in its place.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
Karl Bergvall
on Oct 7, 2013 at 12:07:33 pm
how do you find the location of the build folder ?
